a slight problem...
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=51042
Author:  sdsollod [ Thu Sep 27, 2018 3:05 pm ]
Post subject:  a slight problem...
I've got a slight problem. I made my headstock about 7/16" thick. A little thin perhaps... But, I did not expect that the Gotoh 510 tuners wouldn't go down that far. It looks like I'm about 1/32" too thin. So, they don't tighten down to 7/16". I'm thinking maybe one thing I could do is grind the threaded insert down slightly on my grinder. As long as I don't foul the threads I think that could work. I suppose another remedy would be to use some different tuners, but I sure like the Gotoh 510s and this build is calling out for them. Any thoughts or suggestions?
Author:  surveyor [ Thu Sep 27, 2018 3:13 pm ]
Post subject:  Re: a slight problem...
I can't tell much about the veneer, but possibly scrap the old one and put on a thicker one.
Author:  Chris Pile [ Thu Sep 27, 2018 3:15 pm ]
Short term fix - washers.
Author:  sdsollod [ Thu Sep 27, 2018 3:21 pm ]
I just completed the finishing on this one, probably the best finish I've done. I'm sure not going to remove and replace the headplate at this point... and adding a washer wouldn't be very professional....
So... how about grinding down the threaded insert. Am I likely to booger it up? Does anyone know of other tuning machines that will tighten down to 7/16"?
Author:  SteveSmith [ Thu Sep 27, 2018 3:24 pm ]
Look for some different tuners?
Author:  meddlingfool [ Thu Sep 27, 2018 4:16 pm ]
Well, try it. If you crap out a bushing they're easy to come by. But I'd think that would probably work...
Author:  sdsollod [ Thu Sep 27, 2018 4:51 pm ]
Okay - For anyone that is interested... or has this problem in the future. I went ahead and ground down the threaded inserts for these tuners to fit my "thinnish" headstock and they fit perfectly. Sometimes you have to not be afraid to try something...
Author:  doncaparker [ Thu Sep 27, 2018 4:58 pm ]
You might want to measure the length of the screws and make sure they won’t poke through the front.
Author:  sdsollod [ Thu Sep 27, 2018 5:05 pm ]
Nope. Plenty of room. Its not that thin...
Author:  bcombs510 [ Thu Sep 27, 2018 5:46 pm ]
Nice workaround.
Author:  Ruby50 [ Thu Sep 27, 2018 7:52 pm ]
What about adding another layer to the back strap?
Ed
Author:  sdsollod [ Thu Sep 27, 2018 9:27 pm ]
The guitar is finished. After the endless finishing process I have no interest in going back to add 1/16”. Besides, it looks fine, good in fact and the problem is solved...
